disable vpex auto-upgrade
Description
Disables automatic upgrading on Extended Edge Switching topologies.
Syntax Description
vpex Specifies Virtual Port Extender (VPEX).
auto-upgrade Specifies that the controlling bridge (CB) automatically upgrades bridge port extender (BPE) slots in This command is available on all Universal switches supported in this document. mode (default is enabled).
Default
Automatic upgrading is enabled by default.
Usage Guidelines
Automatic upgrading can occur only when both CBs in the MLAG have the same BPE xmod versions installed, and only after all slots are synchronized between the CBs.
To disable automatic upgrading, you must first enter VPEX mode (see enable vpex). To view the status of automatic upgrading, use the command show vpex.
The following example disables automatic upgrading:
# disable vpex auto-upgrade
This command was first available in ExtremeXOS 30.5.
Platform Availability
This command is available on ExtremeSwitching 5420 and 5520 series switches, and Extreme 7520-48Y switches.
